Fordfarmer
Anyone know how to identify a Red Tiger flywheel? The one from my 134 industrial is different from the single-disk flywheel in the 2000, so it MIGHT be compatible with a double-disk clutch in an x60. Would Ford have had 3 different flywheels? The timing numbers are easy to find and clear, but I haven't found a part number on it. That would make it too easy. I can grab some measurements after milking.
This would be a good one to use, IF it's the right one - it had a drive hub bolted rigid to it, so there is no wear on the face.
