Hi all : I am in need of a used hydraulic cylinder for my FORD industrial 2000 backhoe... I believe it is called the "crowd" cylinder ---The year is '62 and the model of the hoe is
713 with series 840... The cylinder measurements are: closed from center of pin hole to center of pin hole =4', the pin sizes are = 1
/2" and the Inside diameter of the cylinder tube is = 3 1/2" I rather not "cob" it and replace it with a good used one that will fit without
any problems so that is why I am reaching out to all you good Ford people in hopes that I can find one for my needs.. If you email me I
can then give you my contact info , thanks for noow JIM
