ford 640 steering
LarryH
1st time to work on a ford bearing is out of steering and I cant get arms off to remove cover tried heat ----ball joint tool big punch --what am I doing wrong thanks
I have a good bearing puller that I use.
Install it and tighten it up.
Then I use a torch to heat the steering arm.
I have oxy/acet but if you use Mapp gass in your propane torch it will work. Pops them right off.
Be careful working with a torch around the gas tank.
