Dopp Creek
I have replaced the piston rings on my 4000D (3 cyl) and need to break it in. Conventional wisdom is to work it with a plow in the ground but I have no plans for tillage this spring. I don't think any of my neighbors are working ground either (my area is primarily hazelnuts & vineyards). Are there alternate methods? I could drag a heavy trailer up the hills but I don't think that is going to add up to the hours required for ring seating.
Suggestions? Primary duty for this tractor is running a haybine and baler so relatively light duty.
