Finally got the bushings out. Top was easier, was able to weld a few beads on the bush and pop it out with long screwdriver. The bottom, not so easy. ..
Could not get the stick welder to spark. I banged on a pipe foe an hour. Used lots of tools but if I were to do it again, I would buy a few new saw zaw blades, cut bush about 80% through, then chisel from top or bottom. That will split the cut and wa-la, it will pop out. This is what worked for me.
