kennyhatcher
New User
This message is a reply to an archived post by kennyhatcher on July 02, 2016 at 13:06:36.
The original subject was "pto problem ford 7000".
hello
The pto works as long as duel power is on the low side so does anybody known if you take the cover plate on top of the transmission,
the plate that holds the gear shifter,the low side and high side shifter of the transmission. if you take that plate off, can you see the duel power clutch pack or the valve that controls the duel power.
hello
