2000 Offset
steve19438
after looking through the owner manual I am guessing that the trans., hyd., and rear end do NOT share a common sump as does the N series.
if I am correct is Ford 134 suitable for use in the hyd. and 90W mineral oil in the other two?
thanks.
you can put 134 in all 3 or 134 in the hyds, and 80w90 in the trans and diffy.
you will also have 2 reduction boxes that need to be serviced. 134, 80w90 or 85-140 will be fine.
I'd skip the gl 1-3 90wt oil on a 53+
don't forget that funky front steering box too.
Here is a pic of one of my rowcrops I'm changing tires on. See the hub n finals. There is an oil sump/ pan on the bottom, each side.
