TractorLinks.com
Order Ford 2000 Parts Online
2000 Offset
steve19438
03-20-2017 05:06:44
after looking through the owner manual I am guessing that the trans., hyd., and rear end do NOT share a common sump as does the N series.
if I am correct is Ford 134 suitable for use in the hyd. and 90W mineral oil in the other two?
thanks.
soundguy
03-20-2017 11:20:59
 Re: 2000 Offset in reply to steve19438, 03-20-2017 05:06:44
you can put 134 in all 3 or 134 in the hyds, and 80w90 in the trans and diffy.
you will also have 2 reduction boxes that need to be serviced. 134, 80w90 or 85-140 will be fine.
I'd skip the gl 1-3 90wt oil on a 53+
don't forget that funky front steering box too.
steve19438
03-20-2017 12:01:39
 Re: 2000 Offset in reply to soundguy, 03-20-2017 11:20:59
reduction boxes ???
soundguy
03-20-2017 12:16:49
 Re: 2000 Offset in reply to steve19438, 03-20-2017 12:01:39
You have a rowcrop rear end.. It has a final drive on each side, each has a sump/pan.
steve19438
03-20-2017 12:52:23
 Re: 2000 Offset in reply to soundguy, 03-20-2017 12:16:49
no mention in the manual. will have a look-see. (at least not that I saw)
thanks.
soundguy
03-20-2017 13:56:27
 Re: 2000 Offset in reply to steve19438, 03-20-2017 12:52:23
Here is a pic of one of my rowcrops I'm changing tires on. See the hub n finals. There is an oil sump/ pan on the bottom, each side.
steve19438
03-20-2017 15:58:50
 Re: 2000 Offset in reply to soundguy, 03-20-2017 13:56:27
I have seen then but did not know what they are.
soundguy
03-20-2017 16:32:14
 Re: 2000 Offset in reply to steve19438, 03-20-2017 15:58:50
There is a drain and check plug each side
