Bud Kaiser
My 4600 has a fuel flow problem coming out of the shut off valve on the bottom of my tank ( tractor stalled and had to blow air back thru valve to re establish flow). I removed the valve and it was almost
plugged. I noticed it is threaded flush with bottom of tank. Is this normal. Usually my other tractors has the suction to the valve extended up into the tank with a screen on it. What do yall do to resolve
this. Could I put a pipe ( 1/2 in pipe thread ?) and a cut off valve on it to fix the problem ?
