Ford industrial diesel engine
Forum,
Looking at an older Pettibone Skidder with a Ford industrial diesel.Question is there is a part of the manifold I have not seen before. Attached under the manifold is a cast iron box with a cone shaped screen at one end. What is the cone? Is it for spraying in ether? Any and all thoughts are welcome.
Mr. T. Minnesota
What Ford industrial diesel is it? 3 or 4 cylinder? The 1958 4 cylinder diesel engine had a box between the manifold and air breather.
(quoted from post at 04:32:39 03/16/17) What Ford industrial diesel is it? 3 or 4 cylinder? The 1958 4 cylinder diesel engine had a box between the manifold and air breather.
Indford,
Thanks for the reply. Will find out tomorrow if it is a 3 or 4 cylinder engine. Will let you know specifics.
Mr. T. Minnesota
If it's a four cylinder, it could be either the American Ford Diesel or the British Fordson diesel.
Or it could also be one of the English Ford Dorset industrials. The 4-cylinder was a 254, and there were also 363 and 380 6-cylinders, and a 363 turbo.
Forum,
Looked at the Pettibone today. It has a 4 cylinder Ford industrial diesel engine. Looked at the manifold and the cast iron box appears to be a oil bath air cleaner. At one end is a cone shaped screened air intake opening. Curious about the age of this engine? Any and all thoughts are welcome.
Mr. T. Minnesota
