Brian J in MN
Hooray! Got the NEW external filter all hooked up yesterday and the sight glass mounted on the right access cover plate on tranny housing. Filled with oil started up and all three circuits had 180 psi! Improvised oil light sender works(got one from NAPA that goes off at 3-12 psi).
No leaks anywhere and checked the filter discharge in tranny good flow through filter. Put cover back on hooked up pto and shifter cable took her out for a drive and all gears worked(some not too well got a little worried until I remembered I had to set the bands).
This morning went out and had to adjust short shifter cable(only one turn I was too short), warmed it up, set the bands and she works like a million bucks!
I know my Dad is looking down with a grin from ear to ear.
Thanks to all for advice and help (especially Larry for the parts).
Brian
Brian
