Some photos of that 545A
Ultradog MN
Location
Twin Cities
I went back and paid the man for the tractor today.
Still won't pick it up for a couple of weeks yet.
She's kind of a dog, bad tires, tin
is fair. Not sure what I'll do with it yet.
I assume this loader will fit on a 4500?
Looks like it would bolt up to a 4500 but it not the same loader as what came on a 4500.
Front mount is different and it doesn't have the backhoe hooks on the rear of the loader frame.
Backhoe was a factory installed option... it could be
ordered as a tractor, tractor/loader, or tractor/
loader/backhoe. Came with a 3-point if the backhoe
wasn't optioned.
That is one heavy loader,,definitely industrial duty. See the HD front axle used to support that load.
It looks to me like a tractor used by an asphalt company to tear up old asphalt driveways with a Gannon box blade with 5 ripper teeth. The loader was then used to load the rubble into a waiting dump truck.
My brother has a similar tractor made by Massey Ferguson #202.
It was a tough life for a tractor.
Paul in MN
From the paint color on that engine, it looks like it did not come with that tractor. P/S pump and bell housing are the correct faded yellow. The engine block is not.
I've never seen a 545A with that style ROPS and fenders. Anyone know if that is correct for early A-s.
My sales literature lists both the 2 and 4 post ROPS
as being available, and the flat top fenders as an
option to the clamshells.
(quoted from post at 06:42:09 03/15/17) My sales literature lists both the 2 and 4 post ROPS
Thanks for the info. First one I've seen like that.
are both rear wheels the same? - I note that the fronts have 8 lugs which is a step up from the 6 lugs my 4500 has, but the rear wheel I can see is 4 bolts to the rim and a steel center which seems inconsistent with what I'd expect which would be an heavy iron center and 6 attachments to the rim - if those tires are not loaded the machine will barely move itself around, let alone pick up much with that big loader -
sounds like you're more interested in the tractor than the TL combo - -
I've been using my similar to yours/new-to-me 4500 for a few days and I do generally like the machine - heavy and heavy duty - I think yours is better featured and a generation more refined - enjoy your new project -
David
You know,
I looked at the tires and thought? they were
matched Goodyears. The right tire is parked
in a shallow and is a bit low. But it does
look like they are different sizes in the
photo. I will look again.
The rims/centers are one piece type.
The 4 bolts you see are for a wheel weight
someone added - incorrectly.
You can see one of the weights inside in the
rear view photo.
I didnt measure the front lug pattern but
they looked like 8 on 8".
Very heavy up front.
Yes I'm not much interested in the loader.
Would like a short, stout bush hogging
tractor. What's most important to me is how
crisp the steering is. I had a 4400 that I
made nice but the steering just wasn't
responsive enough. So I sold it and am
starting over.
I do like the hard nose. Always wanted one -
just for the looks.
Seller says the motor is tired. Seems
strange that they could have worn out two
engines in it.
It was a municipal tractor. I thought those
would have at least have gotten regular
maintenance.
[/quote]
That engine doesn't say BSD to me. Looks more like a reman. Maybe the fuel system was reused and the injection pump is tired or the injectors need attention. Like you said, hard to believe a municipality wore out two engines, unless they dusted the motor.
Thanks.
Yeah, I'm kinda hoping it's the pump or
injectors and not the engine.
Am going to buy a diesel compression tester
and see what that says. A guy can hope and
or speculate but the tester should tell the
story.
The compression tester was a piece of standard Ford shop equipment that never got used much. You can make your own out of an old injector and a low cost automotive compression tester. The testers sold for diesels can be a bit pricey.
I bought an "old dog" once. Non-running 4 cyl 4000 SOS with the fluid filled pipe/front PTO FEL. Gave #1k. Sold the loader for $500. Fixed up the rest for a reasonable amount and between me, son, and a neighbor, got a goodly amount of use from it.
