2600 hydraulic problem, pulled cover
Eman85
My 3pt stopped working on my 2600. Hydraulics still worked fine through the remote, worked log splitter perfectly. Everyone I spoke to said it's in the unloader valve. I've pulled the cover and I've pulled the plate with the tube that covers the valves. Now how do I get into the valve? The center of the end of the valve has a small hole.
Been a while but I remember using a socket screw/bolt and a bunch of washers to pull it out. Large enough socket to go around the opening, add washers as needed while turning screw to pulling it out.
It looks like small threads in the plug, haven't tried a screw yet but it's about a 10/32. There are 3 valves and with the cover upside down this is the one on the left. I'll try and get a picture.
The threads are 6/32! Used a screw and a slide hammer and pulled the plug. The valve seemed free and has an o-ring on it. There was a little piece of trash, might be a piece of the o-ring. cover had a red gasket and possibly someone was here before. I don't see anything wrong/broken with the linkage.
