192 cu in gas industrial engine
Musky
New User
Long story but, I have ended up with a 192 ford engine that I had hoped to find a project that could use that engine. Maybe an 861 etc. Problem is, it seems everyone is holding on to them as I have not been able to find a likely candidate for replacement.
Would anyone happen to have such an animal or if not anyone who may be interested in the purchase of it (the engine)? Hate to see it not get used. I have no idea of the value. It came out of a R65 Ditch Witch trencher. It has a transmission attached but they were only a 4 speed and the shifter fork is GOA. Everything else appears complete but, does have missing dist. cap.
GOT ONE FROM A DITCH WITCH PUT ON A 960 WORKED FINE--BUT ON THE UPPER RIGHT FRONT THERE IS NO BOLT HOLE TO MOUNT THE 800 FRONT AXLE BRACKET
SO YOU WOULD HAVE ONLY 3 BOLTS TO HOLD THE BRACKET ON--DON'T KNOW IF ALL 192'S ARE THAT WAY OR JUST THE ONE'S OFF THE DITCH WITCH
THE 960 ONLY USES THE BOTTOM TO BOLT HOLES
What's the numbers off the block? I would think it might be a late block cause I have three 192's and all have four bolt to axle carrier.
Kirk
(quoted from post at 21:13:00 03/13/17) Long story but, I have ended up with a 192 ford engine that I had hoped to find a project that could use that engine. Maybe an 861 etc. Problem is, it seems everyone is holding on to them as I have not been able to find a likely candidate for replacement.
Located in Central Indiana, S/E of indy about 20 mi.
I might be interested in either option and am not far from you in SE IN.
Email if interested.
Dean
Be happy to talk about either situation. Reluctant to post Phone# and cant seem to get the PM function to work.
I don't mean to sound stupid but, I don't see an email address I can reply to. I am a long way from being computer friendly. Don't know where to look etc.
I use classic view only.
In classic view, there is a "Send email" link in the lower right corner if the poster has provided an email address.
I provided my email address in my first post. I've provided it again here.
Dean
Dean - I looked through the entire thread in Classic View and every single one of your posts says "No Email" where the "Send Email" link should be.
