Can't Beleve It
I can't believe I took my Jubilee Marvel Schebler TSX Carb apart and can't remember how the dang needle valve spring goes on! I took it apart and then got involved with doing some other things and last night I went out to the shop to put the new kit in and I'm drawing a blank on how it is suppose to go on. Can one of you guys draw me a diagram or post a picture please? At 54 the senior moments are coming more often it seems. I'm laughing at myself so you all can to! Thanks.
Thanks JMOR! That's not exactly like mine but I see by that one how it should go. Mine has the 2 floats on the attachment bracket but basically the spring pushes again the bracket and pushes down on it.
(quoted from post at 12:43:30 03/09/17) Thanks JMOR! That's not exactly like mine but I see by that one how it should go. Mine has the 2 floats on the attachment bracket but basically the spring pushes again the bracket and pushes down on it.
es, sir, well aware that picture was not NAA carb, but thought it might help you. The clip (spring) function is to pull the needle off its seat. Helps with the stuck needle/seat problem.
