For anyone that can assist. I had distributor issues on the 3 cyl Ford 4400 before and troubleshot through help to the distributor. I ordered the mechanical advance distributor and changed it and all worked perfect. The problems started again and replaced again. All and all, I have rewired, changed the coil and resistor, and read voltages and all is well. However, today the tractor started acting up again. From running perfect to a low rough idle and barely running. Carb fuel is perfect and verified on a relatively new zenith carb. Tractor timing is set and all plugs and wires are new.
I have contacted them and they are checking with the manufacturer and was wondering what could be causing this and if anyone else has experienced these issues. Thanks
