o, but I'll try to straighten you out tomorrow.(quoted from post at 20:58:48 03/01/17) I think you have to put a tee in the output side of the pump and plumb your gauge into that tee. I seem to recall seeing folks recommend a 3000 psi gauge and around 2500 psi pressure from the pump but I could be mistaken.
ome places to examine:(quoted from post at 05:16:55 03/03/17) " How would I check leak down in the pressure circuit?"
Well, no need to check for leak down, as you have already verified that it exists. "If I shut the tractor off and put pressure on the arms they go down and...."
...now you just need to isolate as to where. Only you have access to the machine, I'm not there.
