mountaineer2
New User
When I have the brushog attached, the hydraulic system lifts high when the touch control is put in the up position. Then the lift arms slowly drop in about 10-15 seconds. I can pull up the selector lever on the right side below the seat and it lifts right back up again, only to slowly lower down to the ground.
Is the selector lever supposed to stay in the vertical position to control the raise and lowering of the arms with the touch control lever? That's what the manual seems to be telling me, but the selector lever will not stay vertical, it has tension pulling it back down when released.
Could this loss of hydraulic pressure also be due to the wrong weight of oil?
