Installed ROPS, is this correct?
makoman
Got my ROPS on, fits in shed, just barely. The bottom plate has mount for stabilizer bar. Does the tab on the plate that hold the pin go on the inside towards the center of tractor or wheel side?
You'll need to turn the entire base plate around or the stabilizers will foul out against it in the raised position.
Also since no bolts go through the bolt guides on the axle make sure the roll bar is clamped tight.
Thanks. I will switch bottom plates and point pins in. I also have to make holes bigger for the 2 sway chain plates. The existing fender bolts are smaller then the ROPS bolts.
FYI...height of the ROPS on tractor is 84 inches, (7 feet).
75 Ford 2000 with 28 inch tires.
