I purchased temp gauge that screws into the block somewhere. I cannot find where and have looked in my Ford Manual, the IT manual and online. Can someone post a picture for me? Also, I have read some threads where the ferrule was mis-sized. I bought the gauge right here on YT. Will it work stock?
The 4 bolt holes around my PTO that a drawbar hitch would mount to wallowed out and one is partially broken at the corner of the housing. What is best way fix? Weld studs into the holes and put a nut on the hitch plate to mount it instead of using bolts? Have it machined 1 or 2 sizes larger and threaded...hard to do on a tractor that cannot be mounted in a drill press? Helicoils? ????
