Kevfulltilt
New User
I bought what I think is a 1963 Ford 4000 Industrial with a 735 loader. When I bought the tractor the power steering didn't work. It didn't have a filter in the pump so I bought one and put one in. I bought 2 new power steering cylinders, one for each side. I now have the power steering control valve apart. I have bought new bearings for top and bottom and a new "spring washer" for under the nut. Also am replacing one of the springs in the valve (one of the springs looked a little different). There are 6 plungers and 3 springs. There is also 2 horned plungers and there was only 1 bearing between them. By reading here there is supposed to be 2. Can someone please explain the where the horned plungers go and there is a center spool on the block with a groove at one end, does this groove go on the top or bottom? I have been through all over web and through forums and are getting different answers.
