My 3000 presently has a single solid stabilizer which is a real PTA when I move the tractor between implements. Have to use the top link pin to tie it to the lift arm. Have seen the newer adjustable links (link on YT below) but not sure they would work. The solid bar has a crook in it so the bar itself hangs a little below the mount under the fender. The adjustable bars look like they mount straight and wondering if they might have a clearance issue with the axle.
Also, not sure I like the idea of drilling another hole in the lift arm but guess that could be offset with a welded bar under the arm for added strength.
Really like the idea of the stabilizer bars being permanently connected to the lift arms and not having to deal with them when I don't have anything on the 3 point.
So anyone updated your stabilizer bars and how did it work out?
Stabilizer bar
Stabilizer bar
