FordManiac
So I have a 1987 Ford 3910 tractor. I noticed it started running rough and cutting off. After further investigation I found that the fuel shut off valve has a filter which is clogging up with an orange substance. Looking inside of the tank it appears that there is rust formed along the walls of the fuel tank. I drained out all the fuel put a new shut off valve and replace the fuel filters. My question is if I keep the tank full of diesel from here on out will the rust problem be kept at bay and no longer be an issue? I have attached a picture of the inside of my fuel cap to show you what it looks like. Thank you
