Brass plug in bottom of carburetor bowl Ford 850
sixbales
I'm working with a guy that cannot get the brass plug out of the bottom of the bowl on a Ford 850. This is next to the pipe plug/drain plug on the bottom of bowl. Is there a jet under this plug? His tractor has been sitting for a year or more and will only run with the choke out.
Any tips on how to get this plug out without damaging it?
The small plug is simply plugging a hole that was necessary to drill a casting passage during manufacturing. Nothing to access there.
there is a drain plug, and a sinterized plug.. double check, yourself, which one he is trying to remove.
Thanks JMOR and Soundguy, for the quick response. Chris, I am talking about the sintered plug (looked like a brass plug to me). Thanks again to both of you!
I was the guy he was trying to help. Posted this on another forum. I got the plug out using a pipe wrench gently after ordering another carb. The plug did contain a jet for the primary, but this was not the original carb for the 850 so I believe it's configured differently. The carb number was TSX-977 and I was hard pressed to find any info on it. Thanks for the help though, hopefully this helps someone else down the road =)
(quoted from post at 00:35:03 02/22/17) I was the guy he was trying to help. Posted this on another forum. I got the plug out using a pipe wrench gently after ordering another carb. The plug did contain a jet for the primary, but this was not the original carb for the 850 so I believe it's configured differently. The carb number was TSX-977 and I was hard pressed to find any info on it. Thanks for the help though, hopefully this helps someone else down the road =)
ell, a "plug" does not "contain a jet", so precise language or pictures might clarify things. :roll:
TSX 977 carbs were used on industrial 172 and 192 engines. Things like stationary power units.
We used to have a SUL AIR compressor with such a ford engine on it ( and a 977 carb ).
(quoted from post at 10:12:25 02/22/17) TSX 977 carbs were used on industrial 172 and 192 engines. Things like stationary power units.
How do you think it will do on a tractor? Haven't got a chance to tune it yet. I did replace this main fixed jet with an adjustable one that came in rebuild kit
