Brian J in MN
Well, I got the tranny apart today and found my problem with C3. The big snap ring popped out of the groove on C3 drum and it looks like part of the teeth on the outer edge of the groove broke or was broke off prior to my dad purchase of the tractor and it finally jumped out so C3 could not engage properly. Seal rings on main shaft and C sun gear all look good. Planetary gears are not worn, thrust washers all look good as well.
Will have to check scrap yards for clutch carrier and get piston seals, some clutch plates for C3, a few gaskets and we can put her back together!
Brian
Brian
