67 Ford 2000 Gas
Got a 67 Ford 2000 3 cyl gas. At idle, it lets out a fair amount
of white smoke out the crank breather tube, followed by
dripping brown milky fluid. Oil looks clean still, temp seems to
be running normal, antifreeze level appears to be normal.
Idles and runs fine too. This is the second time running the
tractor after it's been sitting for at least 4 years. Any ideas?
Thanks
- Jeff
Condensation build up in the engine, work it or drive it around with rpm's around 1800 for a while to get engine temps up enough to evaporate the condensation.
