Ford 4400 Fuel Line Routing
Ford4400
New User
Looking for some assistance/pictures of fuel line routing for a 4400 Industrial. The lines were cut prior to owning and turned into gravity fed. I am putting a new fuel pump in and remaking the lines. Service manual has not helped. Thanks
I assume it's a gas engine?
It should be the same as all of the ag chassis 3 cylinde 2000/3000/4000 models. Line goes from the shutoff valve at the tank forward along the right side of the engine and across the lower front of the engine and up into the fitting on the fuel pump that faces down, then out of the other fitting on the fuel pump, back across the top of the front of the engine to the right side and back to the sediment bowl, and then from the sediment bowl to the carburetor. Here's a link to the parts drawing for the gasoline fuel system:
http://partstore.agriculture.newholland.com/us/parts-search.html#epc::mr57517ar493414
(quoted from post at 22:01:49 02/08/17) I assume it's a gas engine?
Sean, Thanks for the assistance and the awesome link. Definitely a gas engine and this is a great help.
