Brian J in MN
Well, I got the pressure test done on my dad's 881. Tranny hadn't been touched since 1968 and to my amazement the pressures were bang on(180 psi @ 800 r.p.m.) except for the gears 1, 3, 5 and 7. These tested at 150-165. I think I have a leak in C3 circuit somewhere. I'm hoping it's not the C3 clutch itself. These gears don't engage like they should. It happened all at once too(started it up and backed out of shed and they didn't work right). I have to check for a sticky spool valve and through the interlock system as an o-ring might be out. I did notice when I hooked the gauges up that some oil came out of 1 and 2 test ports but not 3(engine not running). Might not mean anything but something could be plugged somewhere. Any thoughts would be appreciated.
Brian
Brian
