I have a ford 3400 tractor that you guys helped me out alot with just a couple weeks ago so i have another question. I just put a clutch in
it and its a 12" single clutch. I got it mostly bolted back together and thought id check to make sure clutch would work right. Well i have
to have the outside linkage rod as adjusted as short as it will go and will only touch pressure plate about last 1" of pedal travel. I have
the steering column out so i can see whats goin on pretty good. Do them pressure plate fingers have to be adjusted out?? There is a good 2"
between pressure plate and release bearing when pedal is at top. I thought about shortening the linkage rod but something else has to be goin
on, thank you
on, thank you
