Bern, Did as you suggested, mounted clutch on flywheel on the bench. Set all dimensions per the IT manual, cycled the clutch several times and as you said, I was surprised how everything changed. Reset all dimensions and installed on the tractor. Won't know if it is OK until I start it up. Just finished overhauling the engine, so in the process of putting everything together.
I did contact YT and told them of the problems I encountered, said that they would make notes of the problems I had in case I have problems with it.
Thanks again for every ones input.
