mnwisconsin
New User
Hi All, I'm working on a 960 live pto transmission.. the cross shaft itself and the cross shaft bushing that are in the transmission case are very
wore. When you push down the clutch pedal it's really loose fitting and the shaft moves back and forth. I want to replace those bushing. The
different parts suppliers list new bushing for the 3 and 4 speed but not for this 5 speed live pto. The bushings for the cross shaft for the 3 and 4
speeds are very available at the different supplier including this yesterdays tractor parts store. The bushings for the 5 speed are bigger but no
supplies have them except for new holland for a lot of money like $50.00. The bushing that fit the 4 speeds are between $2.50 and $5.00. Can anyone
help me with a source for these bushing. The Ford number is NDA7508A. I dont understand why these bushing for the 5 speeds are not readily available
like the 4 speed smaller bushing. I went into more detail than maybe necessary in hopes this may help others as well. Mark in Wisconsin
