Old 4000 power seeing filter and spring
makoman
Does this look like the corect filter? Seems a little small for the tray. AND going to try to make spring clip to hold filter, but looking in resivuar, where do you hook it?
Can you measure the filter case and post back? Center hole, width and height and the guys here should be able to verify.
Power STEERING...hard to see on my phone.
3 inches across, 1 1/2 high, 1 inch hole. Bought from this sight. Part #AE33538A.
Again, did not see spot to hook spring clip in reservoir.
The hook goes in the hole, it will catch on a lip about 1/2 " down
the hole. The filter I have is 3" dia. 1 3/8" thick with a 1" hole.
If you make one be sure you have plenty of tension on the
spring.
It's not the same as the OEM filter but it looks like it may work if the spring clip is long enough.
Dean
