Brianjbell
All, thanks again for the help on the new to me 4000D. Just a little update on it. Got it apart and the #3 exhaust valve was BAD stuck. Few days of penetrant didn't do much to help it. Took it to the diesel shop to get worked on. All 3 exhaust valves ended up being tight in the guides. #3 had to be driven out and found that the guide is cracked. Off to the machine shop for a new guide to be bored and installed. Someone showed this old girl some love along the way, block was bored and had sleeves installed somewhere along the way. I did notice that it looks like the pistons and valves have been kissin' cousins somewhere along the way. I measured the old head gasket and someone swapped out the .037" one for the early tractors for the .056" one on the later tractors. I'm keeping a photo log of this and will get stuff posted up and shared as soon as I have her running. Hopefully in the next week or 10 days depending on the machine shop.
On a side note, what's this old girl worth when done? She will have decent rubber on all 4 corners, manual steering, 8 spd trans and independent PTO. Will also have new wiring harness (she has no wiring at all now). Not sure that it matters but tractor has 6.00-16 fronts and will have 12.4R36 rears when I'm done.
