Replacing brake cross shaft bushings and seals. After pulling shaft from case, I can see a tube going thru case that cross shaft in in. I haven't seen a tube going thru case before.
Is this something that is in some models or a tube that someone has placed in it?
The last one I did just had the bushings pressed into housing with seals on outside. Never seen a steel tube going through.
