My issue is while driving forward it (seems) to down shift. Reverse acts/reverses normal. I am checking voltage at the Solenoids in the transmission. Tractor not running battery voltage only. Forward/drive solenoid in neutral position has 1.5vdc, forward selected 12.5vdc and reverse selected 3.8vdc. Reverse solenoid in neutral position has 3.7vdc, reverse 12.5vdc and forward 6.0vdc. Tractor running voltage under the dash in harness. Drive white wire has 5.9vdc when neutral and reverse selected, drive selected 14.5vdc. Reverse yellow wire has .8vdc in neutral and drive, reverse selected 14.5vdc. It's a 555d apparently not many people know any about.
