Hi all, I'm new to the forum but have been trolling around for a while and found lots of great information. I've been running Ford tractors for several years but just bought one of my own last year.
I picked up a 1986 Ford 6610 2wd factory cab tractor with 4800hrs. It has the minimec pump and has a new battery. Last winter it seemed to start fine, even in the cold (parked inside, outside plugged in, using thermostart and fuel button). I live in Canada so it can get quite cold here (down to -35c at times ). Recently it started acting up. It has a new fuel filter (it's the single filter model). The tractor starts fine but will only stay running for about 2-3 seconds then dies out. It does this several times before staying running. My first thought was the lift pump/transfer pump or air in the fuel system. So I replaced the lift pump and bled it, did not make a difference. I also changed the rubbers in the nuts on the steel fuel lines at the same time as I had a small leak which is now sealed up. So now it has me confused. I can park it inside my garage (usually around 0 to 2deg C with the heat off) and it will still do it. Is there another way to bleed this, could air still be in it somehow? I have straight fuel coming out the top bleeder on the filter. I've checked the timing and it's bang on 27deg btdc with #1 valves closed. Any help is appreciated. Thanks.
