ford 5600 diesel thermostat where?
dave_in_pa
New User
Overheating issue, temp gauge is hot but radiator is cold. I have flushed, refilled, replaced hoses but no relief. I can't find the thermostat to replace it. There are two hoses I have replaced out from the water pump to upper and lower radiator connection, but did not find it on either. Could it be that thermostat was removed by prior owner and this causes the radiator bypass?
Thanks,
- Dave in PA
