881 fuel gauge
Got lucky the replacement gauge from Ford works with the original sending unit! It is off a little based on fuel level in the tank, but I think I can bend the float arm a little to get it closer to actual level. Pump is rebuilt(just needed a new governor arm and replacement of O-rings). Injectors were only off 200 p.s.i. from spec. All fuel leaks are repaired. She runs like a charm! Just a few minor items on the engine and then it's on to checking pressures in the select-o-speed.
