Brianjbell
All, I ended up pulling the trigger on the 1966 4000D I found on Craigslist. It has poor rubber, but holding air. Comes with a box blade, scrape blade and yard rake, I got it for what the implements are worth . Currently torn down. Has a bad stuck intake valve on #3. Taking any and all suggestions to get it unstuck. Tach shows 9500 hours on it, but engine has been rebuilt at some point. I'm sure I'll be looking to you guys for help on it. It's a bigger beast than the 2000 and 3000 I've had in the past.
Also, I noticed that there is a selector valve under the seat, one of the Ford 3 position jobs. Can I add a remote to lift and lower things like a disk or seed drill?
