85burbanator
Finally had a chance to put the tractor back together after doing the alt conversion and various belts to fit, stock worked with my set up but a bolt that couldn't see made it to short. Found the issue after 4 belt changes lol.
Anyway, change the suction hose at the reservoir and filled the with 5 gallons of hyd. Fluid. I had the valve body off to get wiggle room to the pump and loosely bolted on. Tractor started right up but fluid puked from the valve body. Tightened the bolts and now the tractor just cranks
It was running like a song after the alt swap but the front pump and shaft were disconnected and out of the crank.
