4000 ford power steering
rdelong25
I have a 75 4000 with no power steering. I fill up the pump resovor and it all leak out of the center of the steering column. It looks like some one has change the gaskets at the section where the cylinder lines enter. Any one no where to start to get the PS working again?
Steering box needs to come apart and be re-sealed - it's that simple. Having said that, don't try it without following the manual, or you'll have a bigger problem than before you even started.
I got the steering column removed from the tractor today, it actual came off pretty easy. Going to drop it off at a local hyd. Shop early this week. Is there any pointers I should mention when I droping it off.
