Start Switch on a 4630 Ford Tractor
Charitie
New User
Well the start switch has finally failed on the tractor...corroded and has no detent left in and position other than run. I have fought the heat shrunk boot off of it and see that the pin orientation isn't completely the same from the old and new switch. Does anyone know the wire color to pin number combination for the start switch or even have a copy of the wire diagram?
Any input is appreciated. Thank you in advance.
I'm ready for bed. If nobody hits on this tomorrow when I get up and out for the day, I'll check my 4600 manual (in the shop) and see if there is
a wiring diagram.
