4cyl 2000 carb question
I have an early '60s ford 2000 4cyl. I need to rebuild the carb, but the I&T FO-20 manual, which has "2000 (4cyl)" listed on the cover, but doesn't show which "TSX" carb is used on my tractor. They show a list of 8 different carbs, and their various repair kit numbers, but I cannot find any reference to the 2000 4cyl carb.
Does anyone know what carb kit I need?
I assume that the 2000 is similar to some other model, I think it is similar to the 601. Is this true, and can I use these references in the manual.
Thanks,
Tex
First of if you look at it it is likely to say M/S or zenith etc right on the carb. If it is a M/S carb on the back side there should be a brass tag tha twill tell you what carb it is
I rebuilt my txs from my 65 4000, not too difficult a job. When I had it apart, I took a soft wire wheel to the exterior, made it look new again.
