Gene Sage
What's the difference between a 172 cu. in. Motor and a 192 cu. in. Motor. Same block with no sleeves? Does it involve just pistons and rings? What could I expect to gain in H.P.?
Larger bore.
Blocks are different.
Both 192 CI engines and later 172 CI engines are sleeveless.
All else identical, expect about 7 - 10 PTO HP increase from the additional 20 CI.
Dean
Never owned or worked on a 172 CI diesel but assume that such were sleeveless.
Dean
