ElectricMan
I had a noise on start up after I removed the oil pan I found #4 piston rod cap loose. the lock nuts was missing and I could remove the cap
nuts with my fingers. Upon closer look after the rod cap was off i found #4 crank throw very rough. My question is the most effective way to
resurface the crank. Second is there a way to resurface this without removing the crankshaft. I once had this done on my 1952 Chevy without
removing the crankshaft. I know you guys have run into this in the past any advice will be greatly appreciated .
Many Blessings this year
Electricman
Electricman
