detroitdave
New User
So I had some hydraulic cylinders repacked on my backhoe. I had a company come out and take them off. They took them to their shop and I had a falling out with them. So they gave me my cylinders back in a box with a box of parts and said come and pick them up. Now I need some help getting the hydraulic cylinders back on my backhoe. I have them installed. The hoe is working as it should. Where the pins go in there are snap rings of sorts(see picture). Its so the pins do not come out. I am trying to find out what kind of a tool I need to open these up so I can get the "snap ring" around the pin. The only kind of "snap ring" I have ever seen like this before had a hole at each end. You could then buy a opener and you could put it in the hole and squeeze the ring apart. This ring has no such hole. I went to tractor supply and they had nothing. I then went to auto zone and they had nothing. Can anyone tell me what the tool is called that I am looking for and possibly where to buy it? Also I am sure these are not called snap rings so can you tell me what the correct term is for the item. Also where do I put the hydraulic fluid in? I understand that should be basic but I am assuming its under the hood on the left side and the muffler is blocking me from opening the hood. If I know that is where it is I can consintrate my time there. Thanks to anyone who can help. I am a newbie and appreciate you help.
