Ford4000inTN
New User
Hey All,
Could you please help me identify this Ford 4000. Don't laugh. It is obviously well used, but runs great and I was able to purchase it for next to nothing. We are on a limited budget and are building a home on some land that we purchased.
Here is what I think I know:
1962-1964
Looks like a Jubilee posted in Dean C's Post:
http://forums.yesterdaystractors.com/viewtopic.php?t=1297451
4 Cylinder Diesel
Select Speed-O-Speed Transmission
Mid-Western Front End Loader and Back Hoe Attachments
All of the fluids (Oil, Hydraulic, Transmission and Coolant) appear to be fresh and clean. I work on RV's for a living, so I am comfortable with the Fluid levels and quality.
The Tractor starts and runs great. All gears forward and reverse seem to work great. The Front End Loader and the Back Hoe seem to function well.
Here is what I don't know and would like your help with:
What year and sub model is this tractor. The serial number is gone (battery corrosion most likely). Please see the pictures that I have posted.
The Select-O-Speed transmission selector has red lines through gears 6 and 7. I am doing this from memory, might be other gears but it is two gears in a row. Kind of like it is ok to use gears 1-5, not 6-7 and 8.
Also, if you notice anything in the pictures that you would like to comment about or offer any advice about I would be very appreciative.
Thank you in advance for your help.
Greg in Tennesse
1962-1964
4 Cylinder Diesel
Greg in Tennesse
