3 point does not work. Lift reservoir had a lot of water with the oil so I drained and added fresh oil. No joy. Tried every position on controls, nothing. Bled pump nothing.
Went back a couple of weeks later, 3 point worked but all the action occurred in the top 1/4 of the quadrant. Must have cycled it 50 60 times and worked.
Finally got a chance to get it into my shop for clutch replacement, no 3 point action. After clutch replacement, tried 3 point, nothing. Bled pump, nothing. Pulled side cover couldn't see anything leaking and tried moving the position control valve but nothing happened. Check pressure as described in the FO 20 manual and pressure was where it needed to be. Yes, I followed the instructions to a T to check the pressure.
Not sure where to go now. Is the next step to pull the lift cover? What should I look for? Seems like something must be stuck as it worked one day nad then not again.
Any help is appreciated as I plan to pull the left cover if I can get the pin out of them left lift arm. That sucker is rusted tight.
Side note this tractor has a Sherman combo trans and I really like it!
Thanks all.
Thanks all.
