marcusmerritt
Ford 2000; 3 cyl. gas; 4/1 trans....From YT I ordered front and rear tie rod ends to replace the worn units on my tractor and was looking over the steering links and have a couple questions. The tie rod replacement is pretty straightforward but I notice that the left drag link is 33" long and the right is 30 7/8" long. Is this typical of other 2000/3000 tractors? If so, why the difference? Tractor has manual steering and there are no PS mounting holes in the drag links.
I know the tie rod ends are worn and they provide a lot of play in the steering. However whenever I need to make a fairly sharp turn, it feels like the leading front tire goes way beyond the angle of turn and becomes almost 90 degrees to the body of the tractor almost to the point of me thinking it's gonna roll off the rim. Might this be an indicator of wear in the spindles or other connections or bearings?
Other than measuring the current tie rod end imbedments in the drag links, is there a better way to set the tie rod ends so the tractor front end tracks straight?
Thanks in advance for any sage advice you can provide.
