851tractor
New User
Hi, first time posting on here but have used the site several times for some very good information. I have a Ford 1957 851, that is gas. My problem is when I am at idle or any gear moving, the throttle lever when not stay where I place it. I will have to manually hold it above half way because it will just pull back to a lower RPM. I have checked to make sure the battery box and nothing else was not binding or in the way. I took apart the circular part under the box and cleaned it and greased it, with no improvement. If the engine is completely turned off, the lever will stay where I put it.
